MURPHY SAD 94 [SCH].
189.6 KB
Looking for similar murphy manual?
ION Archive LP Turntable
This is a compact design to I guess transfer the vinyl into MP3 format.
Complaint was when the arm was moved the tt dont spin, confirmed that as
theres a leaf switch to sense arm movement,
and its fed to a main pcb with all the IC's that I guess handle all the
stuff. The switch is ok, and I remember seeing 14V or so on the motor pins
frm the PCB, so I figured perhaps theres anough current to spin the motor and
focused on testing the motor.
Manufacturer does not supply the mainboard that feeds the motor but
the motor can be taken apart and after I opened it and
disconnected the small pcb fron the motor terminals and apply power
directly, it spins w 12v. theres a small electrolytic cap on the pcb 25V / 22uF and an
AN6652 4 pin T0-220 type case IC that I guess is some kind of speed control
circuitry.
The drive Motor is an EG-530-SD-3F, main board is stamped K-13007.
Gonna check the cap, but after searching this IC and its
applications with the motor, I see its popular and some drawings show how its used to regulate the 78,33
and 45 rpm speeds.
This drawing looks pretty much what I see in there:
https://tectronelectronics.eu/images/thumbnails/465/465/detailed/31/eg530.jpg
I have replaced the IC and the cap, but the motor still does not turn. The main pcb
is proprietary and cant be purchased, and I think it is giving the op-amp IC a reference signal.
Is there a way to bypass that signal or fool the IC to believing its on to test it out?
Photo showing the motor pcb :
http://www.mediafire.com/view/s79blgku1503mtg/HPIM0643.JPG/file
Photo of motor under test:
http://www.mediafire.com/view/thhgvcwac8al7gu/HPIM0635.jpg/file
57A jelölésű SMD alkatrész beazonosításához kérnék segítséget
Üdvözlök mindenkit!
Szeretnék egy kis segítséget kérni, mert elakadtam egy készenléti táp javításával.
Egy erősítő kis teljesítményű 12 Voltos kapcsolóüzemű készenléti tápja lenne.
Van benne egy IC ami valószínűleg PWM Controller, de nem találtam róla semmilyen információt.
A felirata 20F09  de szerintem a lényeges információ az 57A lenne.  SSOT-6 vagy SOP-6 tokozású.
Addig jutottam, hogy amennyiben 54A lenne a felirat, akkor NCP1254 lenne, de nem az.
Talán más ügyesebb, mint én, vagy már találkozott ilyen táp IC-vel.
Köszönettel: Hifista
AIWA AD-F260 mechanika javítás - Szerviz doksi kellene a javításhoz
Tisztelt Tagok!
Meg kéne menteni egy ilyen remek kis magnót (igen tudom, hogy az F220 a csúcs, de nem mindenkinek jut belőle...) Sehol (itt a tanyán sem) találok hozzá olyan SM-t, ami tartalmazná a mechanika rajzait esetleges beállításait. Csak kapcsolási rajz van fent.
Tudna segíteni valaki ebben? Van valakinek esetleg ilyen manuálja? (A wanted-ba is feltettem, de csak megoldatlan sorokat látok... :-( )
Előre is köszönöm!
Gábor
Hangszóró peremezés
Adott egy pár 30 cm és mély hangszóró pár, újra lett peremezve, eredetileg szivacs perem volt,de a szaki vászon peremet tett helyette. A minőséggel nincs gond, szépen megcsinálták,de kérdésem hogy ez így nem befolyásolja mondjuk az "eredeti" hangzásban?
